C2 carb to manifold spacer/heat shield - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1364
    Does anyone know of a carb to manifold spacer, GM for some other Corvette or other GM application but will work or after market, with or without a heat shield that has a center divider , separate primary and secondary holes on one side and single oval hole on other side to match '67 L79(or other similar design) stock manifold. All the ones I know about have a single square hole. Does having just the single square hole in spacer effectively making an open plenum chamber hurt performance?I want a spacer to cut down on carb heat.I know, I know, it "won't judge."
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 carb to manifold spacer/heat shield
    Some have blocked off the entry and exit holes of the exhaust crossover to reduce heat. Some recent posts about doing this are in the archives.
    • Timothy B.
      • April 30, 1983
      • 5202
      Bill, Have you blocked the crossover like Jim suggested? Run your initial timing at approx 10* BTDC and see if that helps some.
      In a worst case there is a heat shield used on Holley LT1's that may fit but I am not sure of the throttle blade diameter. I bet you can get one from Holley for the 4160.
      I have found that blocking the hot slot and after a drive, I can hold my hand on the float bowl and the fuel is just warm. These Holleys have a primary and secondary idle circuit so fuel is always circulating through them..
