283 crank case vent tube - NCRS Discussion Boards
  • Chris S.
    • March 28, 2007
    • 139
    can anyone send me a picture of correct bolt head on the ccv tube, the bolt located at top of tube. JM says parkerized (not sure what that means). Thanks
  • Tom D.
    • September 30, 1981
    • 2138
    Re: 283 crank case vent tube
    I think you can find the term "parkerized" using the Search option above.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
      • 15706
      You can find a better explanation by googling. It's commonly used on firearms, and a common automotive use is on camshafts to aid in the break-in process. All GM OE camshafts are Parkerized as are F-M and Dana replacements. Among aftermarket vendors, Crane is the only one I know of that Parkerizes cams, and that's why I only recommend these three manufacturers for replacement camshafts.
      I question whether Parkerizing was used on the bolt for a simple non-critical, non-structural application. It looks a lot like phophate, which is an inexpensive process that provides modest corrosion resistance.
        The JG description is in error; GM didn't Parkerize bolts. I think they meant "phosphated".
        • Chris S.
          • March 28, 2007
          • 139
          any one have a picture to compare with what i have. i was hoping anyway.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17773
            Chris, crankcase vent tube bolt photo. Bolts had a bluish tint to them. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Chris S.
              • March 28, 2007
              • 139
              what did it have for markings, mine has an L? Blueish tint like gun metal?
              • Gary C.
                Administrator
                • October 1, 1982
                • 17773
                Chris, most common is the round no logo same as the photo previously posted. B, BC logos have also been seen. L logos use was common in 56-7 and probably were used as well. Gary....
                NCRS Texas Chapter
                  I'd sure like to see the GM drawing for that bolt (#100118) to see what finish was specified; having spent a good hunk of my career at Chevrolet Engineering and being familiar with the constant cost pressures on release engineers, I can't imagine them spending any money for a premium finish on a Grade 2 bolt that spends its entire life in a hot oil mist.
                  • Chris S.
                    • March 28, 2007
                    • 139
                    maybe they where bought at a surplus sale, kinda a strange bolt indeed. do you guys recommended trying to get it blue looking?
                    thanks guys.
