Re: TI distributor advance curve
I appreciate that Mike. I do not have a part number band on the distributor. It came with the race car and 20 years ago the guy i bought the car from told me it was an L-88 distributor. It does appear to have a partial not double oil groove. I would be happy to send you detailed photos of any portion of the distributor to help ID the unit. My use is strictly road racing. The motor is a racing 327. Soon to be with Rochester fuel injection. Calculated 14/1 compression ratio. Highly modified original 461 heads. Headers, 14 quart wet sump oiling system etc..etc. my rough logic is to get all the advance in around 3000 RPM and have a timing at lower RPM that will allow it to idle. This may be the wrong approach. No real drivability issue. It's either WOT or on the brakes. There is some modulation in the corners but the RPM rarely falls below 3500 RPM.
