1968 1969 Corvette flashers - NCRS Discussion Boards
  • John M.
    • January 1, 2000
    • 175
    I was looking in the latest NCRS Judging guide for flasher numbers for 1968 1969, there is no refrence to the number, any help..........Thanks in advance
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 1968 1969 Corvette flashers
    John & Pam - I'd expect the following flashers:
    1968 Turn Signal Flashers - A Signal-Stat 145 non-DOT w/ either a yellow/gold anodized metal embossed 145 on the top (early car) or metal cover w/ yellow 145 silk screened on the top (later car) OR a Tung-Sol 323 non-DOT w/yellow plastic cover embossed on the top.
    1968 Hazard Flashers - A Signal-Stat 175 non-DOT w/ either a green anodized metal embossed 175 on the top (early car) or metal cover w/ green 175 silk screened on the top (later car) OR a Tung-Sol 552 non-DOT w/natural metal cover embossed on the top OR an IDEAL 552 w/ metal cover & silk screen around the cover.
    1969 Turn Signal Flashers - A Signal-Stat 145 non-DOT with metal cover w/ blue 144 silk screened on the top OR a Tung-Sol 224 non-DOT w/ blue plastic cover embossed on the top.
    1969 Hazard Flashers - A Signal-Stat 175 non-DOT w/ metal cover w/ green 175 silk screened on the top OR a Tung-Sol 552 non-DOT w/natural metal cover embossed on the top OR an IDEAL 552 w/ metal cover & silk screen around the cover.
    Hope this helps. Pete
    • John C.
      • January 1, 2005
      • 616
      John and Pam
      Attached are photos of the signal flashers for my 68 (yellow cover) and 69 (gold cover) cars.
      John
      • Terry B.
        • August 31, 1999
        • 607
        John & Pam
        The position of the turn signal flasher changed locations in production during the '68 year. Mine is located under the radio (Built December '67) and you have to pull the driver side console inspection plate near the gas throttle to find it. Other '68's are found under the passenger side dash and possibly in the jack compartment, I believe. The point of all this is the turn signal flasher may not be easily accesible and therefore, not judged.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Peter L.
          • May 31, 1983
          • 1930
          While the visual confirmation of a flasher might not be possible because it's where the sun doesn't shine, I would suggest that the flasher or at least having a flasher is in fact judged during the Ops Check. In addition, for those of us who drive our Corvettes having the appropriate fixed load flasher, i.e., a 2 lamp flasher in a 66 or 69, or a 3 lamp flasher in a 67 or 68, in the turn signal system is an important safety item so you'll know if the brake/flasher element of a bulb has failed. Pete
            • 15616
            Originally posted by Terry Buchanan (32872)
            John & Pam
            What you are finding in the jack compartment is the flasher for the UA9 alarm system, if the car is so equipped. No alarm, no relay nor flasher in the jack storage compartment.
            • David L.
              • July 31, 1980
              • 3310
              John & Pam,
              I have several NOS yellow/gold embossed 145 flashers. I sent you a PM.
              Dave
                • 15616
                So long as we are on this subject -- is anyone interested in the date codes ont he flashers?
                • David L.
                  • July 31, 1980
                  • 3310
                  My NOS embossed yellow/gold anodized metal 145 flashers are dated "T 444" (44th week of 1964), "T 475" (47th week of 1965), and "T 495" (49th week of 1965). All were made in Toronto ("T").
