C-1 1958 window felt - NCRS Discussion Boards
  • Susan G.
    • May 31, 2005
    • 136
    Hi,
    I have replaced the window whiskers in my door and when the window goes up and down it is binding on the metal trim of the whisker. The trim was sitting on top of the window post but now is well below the curve of the post by approx. 1/4 inch. This is causing the binding I think.
    It has been suggested to me to cut the metal trim at the front end (the curve end) so that there is not as much going up the post by the 1/4 inch that it has dipped down. The idea being it will sit higher on the chrome window post. I hope I have explained clearly. Is there another solution to this problem?
    Thanks for your help
  • Howard M.
    • June 30, 2000
    • 124
    Re: C-1 1958 window felt
    Susan:
    Had the same type of problem on my '60 with the aftermarket whiskers. Remove the door panel and flatten the metal trim in the area where the window frame passes through. Not pretty but functional.
    You can also take everything apart, remove the staples holding the felt to the metal backing, and reposition (restaple) the felt so it rides higher in the window opening channel and the trim is above the post. A pain, but done right.
    • Frank P.
      • April 1, 1985
      • 64
      Susan:
      Also, spray the window run with silicone and the window will run very smoothly.
