57 fi filter housing - NCRS Discussion Boards
+ More Options
Posts
  • Chris S.
    • March 28, 2007
    • 139
    I noticed i have a rounded inlet and outlet with a vin #5277. The jm is saying sqaure after 3200 car? Would a person recieve a deduct in this situation?
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 57 fi filter housing
    yes, but it'd be a minor one. check the mounting bracket(underside) for evidence of manufacturer's logo stamping(which repos usually lack). advertise in Driveline that you'd like to trade the round version for the squared critter.good luck,mike
    • Chris S.
      • March 28, 2007
      • 139
      i do have the weep hole and "b" marking.
      thanks for sharing.
      chris
      • Bruce B.
        • May 31, 1996
        • 2930
        Chris,
        Attached are pictures of the "B" marking on the bracket and of the weep hole.
        Don't forgrt the B & H bolts holding the canister to the bracket.
        • John D.
          • December 1, 1979
          • 5507
          Chris, Note that Bruces nice photos has the B logo as mentioned. Also note the location of the logo. On a typical repro for some unknown reason the "B" logo is at the opposite end of the bracket.
          JD
          • Gary C.
            Administrator
            • October 1, 1982
            • 17723
            John, I have a couple of brackets with the "B" logo close to the center bend. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • John D.
              • December 1, 1979
              • 5507
              Gary, So your brackets are repros then. You know its a very nicely made bracket. A couple of times I tried to polish out that B but it's hit so hard and so deep I couldn't do it. JD
              • Gary C.
                Administrator
                • October 1, 1982
                • 17723
                John, both are original brackets. One was on my '57 when I bought it in 1978 and the other came with a complete 250 HP engine bought in 1982. Don't think John Smith was reproducing the brackets then. The "B" is about 1" off of the center bend. The one I replated lost most of it's "B". Gary....
                NCRS Texas Chapter
