65 oil assembly question - NCRS Discussion Boards
  • Joseph P.
    • September 7, 2009
    • 138
    I have a 65, 327 in which I removed the oil assembly. I was doing an oil change and just wanted to clean it up. I did not take notice on which side the small incased spring in the assembly unit should be positioned. Should it go towards the engine or the fender? I looked in the AIM sheets but did not see any detail showing this. I did not want to guess and have an oil problem. ( I know Murphy is in the garage with me and if I guess he will make me pay). Thank you for your help all info is greatly accepted. Joe
  • Bill W.
    • November 1, 1977
    • 402
    Re: 65 oil assembly question
    Joe,
    Not sure I understand the problem, but if you are refering to the filter bypass assembly, install it with the spring loaded movable button facing down. Engine or fender makes no differance. Bill
    • William C.
      • July 15, 2009
      • 239
      I assume you are referring to the oil filter bypass valve. The 67 overhaul manual shows the valve toward the fender. I will email you the picture.
      • Joseph P.
        • September 7, 2009
        • 138
        Thank you much. I didn't do the best job at verbizing the problem but you hit the nail on the head. The spring part I assemble no problem but when I removed it from the block I did not notice if the offset for the spring was towards the fender or block. I didn't want to assume anything. Thank you for the clarification. Joe
          Bill -
          It could just as well have shown it the other way - it doesn't matter which way it's installed.
          • William C.
            • July 15, 2009
            • 239
            John.. I agree either way is OK. I had never questioned it in he past.
            • Joseph P.
              • September 7, 2009
              • 138
              Thank you gentlemen. The picture helped alot. I now know the anwser thanks to all of you. I learned something today about my car so for me it's a great day. I appreciate everyone's help. Joe
