1970 Odometer Reset Cable - NCRS Discussion Boards
  • Robert S.
    • May 31, 1988
    • 81
    My brain fade is acting up. Is the odometer reset cable housing threaded into the speedo? What size wrench is required to remove it? Thanks.
    Bob
    • 6960
    Re: 1970 Odometer Reset Cable
    It does thread into the back of speedo. wrench size ? 3/8 7/16
    • Don L.
      • August 31, 2005
      • 1006
      Might be a good idea to start with a 1/2"(?) wrench. That would be to remove the driver seat, thereby enabling you a little better access to the back side of the speedo head. You'll likely want to drop the steering column too. You're gonna LOVE this job. I came away cross-eyed after my turn. I had a hell of a time seeing the connection, let alone getting the wrench on it properly.
      As I said in an earlier post on the subject, the replacement of the trip odo reset cable is one of the most memorable/difficult jobs I've done in the 5 years I've owned my car...
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Robert S.
        • May 31, 1988
        • 81
        I know it will be fun, I just finished changing the vacuum hoses. While I'm there I should ...........
