57 breather cap - NCRS Discussion Boards
57 breather cap
  • Chris S.
    • March 28, 2007
    • 139
    57 breather cap
    can someone give me an opinion of this cap, it appears old but i am concerned with the spring rivet.
    • May 31, 1974
    • 8384
    Re: 57 breather cap
    i'm used to seeing a pseudo pop rivet( as if the gun was on the opposite side of the spring) but which doesn't have a nail head. there is no central hole in the rivet you show. mike
    • Doug F.
      • November 1, 1983
      • 322
      Re: 57 breather cap
      here is a pic of a 57 cap i've had for decades, i think this is the rivet mike speaks of
      • Chris S.
        • March 28, 2007
        • 139
        Re: 57 breather cap
        i can see what you mean and thats what i thought. are the repo's from any suppliers showing them correctly?
          • May 31, 1974
          • 8384
          Re: 57 breather cap
          not that i'm aware of. recently got one from CC and its like the one you pictured.i suppose a fella could get creative with a drill motor and couple different sized drill bits and make the repo look like the real mccoy. mike
          • Doug F.
            • November 1, 1983
            • 322
            Re: 57 breather cap
            the last repo cap i got was pop riveted, if you squint just right it looks ok, but it still isn't exactly right, i'm with mike, i'd rather have the solid rivet and work it a bit
            • Tom P.
              • April 1, 1980
              • 1815
              Re: 57 breather cap
              And do judges pull the caps off and look at the rivet??????????????
              • John D.
                • December 1, 1979
                • 5507
                Re: 57 breather cap
                Tom, YES.
                None of the repros are correct although some are configured better than others. By that I mean the oil oil area is much better on some than others.
                No I don't have any original oil caps. Half of NCRS has called me for them.
                Now I don't have the latest 56-57 manual but the older JM shows nice pic or sketch of original oil caps.
                • Tom P.
                  • April 1, 1980
                  • 1815
                  Re: 57 breather cap
                  Originally posted by John DeGregory (2855)
                  Tom, YES.
                  Well with that in mind, can you tell me when/which caps had OIL-OIL and which caps had OIL-AC?
                  • Jack H.
                    • April 1, 1990
                    • 9906
                    Re: 57 breather cap
                    This is covered in the various Judging Guide books. Actually there are three versions of oil cap emboss to understand:
                    (1) 56-59E, Oil-Oil with 'slit' shaped reinforcements
                    (2) 59L-61E, Oil-Oil with 'D' shaped reinforcements
                    (3) 61L-62, Oil-AC with 'D' shaped reinforcements
                    • Joseph T.
                      • April 30, 1976
                      • 2074
                      Re: 57 breather cap
                      Aren't there two types of 1957 oil caps..open and closed.
                      Joe
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        Re: 57 breather cap
                        Joe
                        yes GM changed them on SHP engine because the vented cap allowed oil mist to come out on the engine
                        • Richard T.
                          • February 1, 1979
                          • 858
                          Re: 57 breather cap
                          It's a repo
                          • Chris S.
                            • March 28, 2007
                            • 139
                            Re: 57 breather cap
                            yes vented and not vented
                            • John D.
                              • December 1, 1979
                              • 5507
                              Re: 57 breather cap
                              I guess I have to study the judging manuals as I didn't realize the 56-to 58 style cap was also used on early 59.
