Hi,
I've got my dashboard apart and putting in the correct radio (mono)to replace the bubba boom box assembly. I have a couple of questions to correct bubba's wiring.
The radio was purchased from corvette specialties and was rebuilt and tested.
Don
- On the power supply to the radio; I can see the blue and green wires that go from the harness to the radio. For the black wire, the is black ground wire hanging from the one of the metal braces. Is this the correct black wire or something different?
- For the 2 kick panel speakers, there are t shaped pig tail connectors with a black and green wires. The only open connection on the mono radio is on the side with a flat connector with 3 connection points. The middle appears to be a ground and I cannot see colors on the from and rear wires going into the radio.
- The radio has a white wire comong out of one hole on the top of the radio and back into another and is taped down with black tape. Is this anything I need to address.
Don
