Valve cover paint gloss - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7157
    I am replacing my '67 L71's valve covers, and have painted the replacements with the recommended Seymour's Chevy Orange paint, but the gloss on the new paint doesn't look as shiny and glossly as the old ones, it looks more semi-gloss. Is this a problem for flight judging? Should they be high gloss, or like the door jams, etc. the lower gloss the better for judging? Thanks.
    • 6950
    Re: Valve cover paint gloss
    Mike, I am pretty sure thats what the judges look for, to glossy will get a deduct.factory coverage was not that great so to much paint will also.
    • Michael J.
      • January 27, 2009
      • 7157
      Thanks, that is what I would have guessed too.
      • Bruce B.
        • May 31, 1996
        • 2930
        Mike,
        If you do need to add more gloss just get some good clear and spray them.
        • Michael J.
          • January 27, 2009
          • 7157
          Right, thanks for the tip. I am just afraid to use a clear coat since they will probably deduct for that.
            • 11678
            You may have painted them a bit "dry", too.
            You could always wet sand them with 600 and then hit them again with paint. Get a bit closer to them when you spray, apply a bit heavy, and you'll get gloss.
            However, I think original was closer to semi-gloss.
            • Michael J.
              • January 27, 2009
              • 7157
              Thanks, yes I did paint them a bit dry, as I am always afraid of runs. I think I will leave them semi-gloss and see what the chapter judging says.
