1970 Carburator Mounting - NCRS Discussion Boards
  • Les G.
    • December 5, 2008
    • 158
    In the Judging Manual for a 1970 it says that the carburator is mounted with 4 bolts. In the AIM it says that the rear of the carburator should have studs. Which is correct?
    • 15616
    Re: 1970 Carburator Mounting
    I assUme you are referring to a Rochester Q-Jet. There was recently a thread on here in which this issue was addressed, and as I remember the answer depends on the year you are asking about -- so it may be in your best interest to share that information with us.
    I am not sure that the thread to which I am referring started out discussing the method of fastening the Rochester carburetor so searching may be difficult. It may be better to hope that those who commented on this will see your post and again contribute their wisdom.
    • Mike G.
      • July 31, 2002
      • 709
      the lt-1 had 4 studs.
      • Les G.
        • December 5, 2008
        • 158
        It is a 1970 with a Rochester Q-Jet. L-46 Engine. March production date.
        • Jim T.
          • March 1, 1993
          • 5351
          My original owner 70 came with two studs and two bolts. Studs/nuts on rear carb mounting and two bolts at the front.
          • Bill L.
            • February 1, 2004
            • 1403
            June 70 L46 4 speed. Two studs two bolts. No washers.
              • 3416
              Hi Les,
              Just a note about my 71... 2 long bolts with washers, 2 studs with nuts and washers, and the nuts are quite THIN compared to a typical nut.
