942 Bore limit - NCRS Discussion Boards
942 Bore limit
  • Peter J.
    • September 30, 1994
    • 586
    942 Bore limit
    What is the safe bore limit on a 1966 427 - 942 block?
  • William C.
    • May 31, 1975
    • 6037
    Re: 942 Bore limit
    .060 is generally considered safe, although with the use of sonic testers by many machine shops today a block can be evaluated individually as to suitability beyond that size. I also had one bored and sleeved in all 8 holes to get it back to std bore, so there are options...
    Bill Clupper #618
    • Peter J.
      • 586
      Re: 942 Bore limit
      Thanks - Bill
      • Philip C.
        • December 1, 1984
        • 1117
        Re: 942 Bore limit
        Pete best advice, make sure you use a professional machine shop. They know if the block has a good core shift and have little tricks, like shimming the boring bar over to clean the side of the cylinder that has the rust or pits, damage etc. Phil 8063
