The old 427 in the 67 sure leaks a lot more oil than I would like. Makes a mess. Any insights to possible sources would be appreciated.
I am sure the rear main seal leaks. What has me most puzzled is a significant amount of oil accumulates on the right rear of the block. The upper right rear flange that receives the transmission (the area where the casting number would be if it was on the right) is saturated with oil. The rear of the head is clean and dry. I have a little blow by evident around the valve cover oil filler cap and the grommet in the right valve cover, but cannot find any real leaks around the valve cover gasket. Around the distributor looks pretty clean too.
Any other areas to check would be appreciated.
Gary
Gary
