hood on one corner pops up..this the correct way to fix it? - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    Since I got the engine back in and the hood back on the right corner pops up after driving for awhile and hitting bumps etc.
    I noticed the pin thats fixed on the firewall is slotted..if I screw this downward would that correct this probably?
    I haven't tried it yet because I was afraid it would make the hood go inward on that side too far and crack the paint or something, if I try it I will just do it a little at a time ofcourse.
    I guess the right way would be screw it downward right or would letting it out some correct this?
  • Harry S.
    • July 31, 2002
    • 5349
    Re: hood on one corner pops up..this the correct way to fix it?
    What year are we talking about?
      • 6960
      Brandon, try to back the slotted hood stricker out about 1/2 to 3/4 turn, keep in mind that this will ever so slightly raise the hood ,so if the hood is recessed on the side this will bring back to level w/fender.
      Harry, sorry for jumping in I know Brandons car.(68 C3)
      • Brandon T.
        • October 23, 2008
        • 872
        as Ed said this is a 68.
        I wasn't sure if I needed to screw it down or up sounds like you think it needs to be backed off and come up.
        I'll give it a shot, can't try it out thought it's a mess outside! pouring rain.
          • 6960
          Brandon, just in case, the lower part of striker does have a locking device that will have to be backed of to make the adjustment. a light tap with an old screw driver and hammer should be all you'll need.
          • Brandon T.
            • October 23, 2008
            • 872
            ah ok, yeah I know what you're talking about I went out earlier and backed it off 1/2 of a turn but I didn't back off the lower part so I don't know if backing the slotted head off did anything or not I'll take a closer look later.
