C1 Tach drive versus PS drive unit - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    I have incorrect generator for my 1960 restoration project. It is a 1102115, which I believe was a 57 passenger car with power steering drive unit. I do plan to try and get a correct generator, the 1102043.
    Is there a difference in the PS drive unit and the Tach drive unit? Can I use the PS drive unit off the back of the 1102115 generator on a 1102043 generator to drive the Tach?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Mike M.
    • May 31, 1974
    • 8409
    Re: C1 Tach drive versus PS drive unit
    i believe the armature from a PS generator same as armature from a tack drive generator so you should be able to bolt the tack drive assembly to the back of a generator equipped with the PS/TD armature.mike
    • Donald H.
      • November 2, 2009
      • 2594
      Thanks Mike. I Have seen other references that the armatures are the same. So I am fairly confident that the PS drive unit will mount OK. I was more wondering if it would drive the tach OK and accurately. If the PS and Tach drive units are geared the same?
      Don Harris
      • Ridge K.
        • May 31, 2006
        • 1018
        Exactly the same, Donald.
