Missing Vin Plate - 1960 Corvette - NCRS Discussion Boards
  • Gary R.
    • January 1, 2000
    • 8
    I am missing a VIN plate that should be on the L/F door post. It is an early S/N car. There is not a VIN tag spot welded on the lower steering column. There is, however a correct VIN# stamped on the R/F top of he frame under the exhaust manifold.
    Does anyone know of a source for a proper VIN tag to install on the door post? Is it legal? Any reason for the frame stamp?
    AGR
  • Valeria H.
    • July 27, 2009
    • 463
    Re: Missing Vin Plate - 1960 Corvette
    I don't know the answer but I'd like to watch this post.
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
    • Mike M.
      • May 31, 1974
      • 8400
      AGR
      the frames were not vin stamped under the exhaust manifold. they were stamped on the drivers top side about where your left buttock would be located should you be seated in the vette. i'd make sure the frame(at the factory stamp location i mentioned previously) and the title have matching vin #'s before proceeding. replacement vin plates are available. mike
