'69 435 pistons - NCRS Discussion Boards
'69 435 pistons
  • John R.
    • November 1, 2005
    • 433
    '69 435 pistons
    Does anyone have a photo of a stock piston for a 1969 427, 435 car? Or where I may be able to view one on the web? Thanks.
    • 43247
    Re: '69 435 pistons
    John------
    I do not have any of these pistons [not for sale or otherwise] to photograph for you. These things were discontinued a long time ago. The last size available was the +.030" and it was discontinued in July, 1984. However, these are the part numbers you're looking for:
    GM #3888342------std
    GM #3888343------+0.001"
    GM #3888343------+0.030"
    GM #3888345------+0.060"
    If you can find a photo of any of these, you'll have a photo of the dome configuration you're looking for.
    By the way, these pistons were used for all 1966-69 427's with SHP, Corvette or otherwise.
    • John C.
      • January 1, 2005
      • 616
      Re: '69 435 pistons
      John
      Attached are some photos of a SHP piston taken out of my 68 435hp engine.
      John
      • John R.
        • November 1, 2005
        • 433
        Re: '69 435 pistons
        Beautiful! Just what I wanted to see. Thanks for taking the time to assist.
        Joe, thanks for the part numbers too.
          • 43247
          Re: '69 435 pistons
          John------
          Bear in mind that the part numbers I provided are for the finished pistons. The number seen on the underside of this piston is the forging number for the blank from which the finished pistons are machined. You will note, though, the "relationship" of that number to the part numbers.
          Also, I believe that forged pistons of this dome configuration, or very close to it, are currently available from Speed-Pro/Sealed Power (Federal-Mogul).
