'62 Water Pump Mounting Bolts - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    For a '62, did the bolts that mount the water pump have washers? If so, were they lock washers? Or, regular washers?
    • 43247
    Re: '62 Water Pump Mounting Bolts
    Christopher------
    As far as I know, no washers, split lock or flat, were ever used, for 1962 or any other year, for any small block or big block waterpump attaching bolts.
    • John F.
      • March 23, 2008
      • 2415
      No washers on mine. (62)
      John
      • Dan D.
        • November 5, 2008
        • 1323
        Does 'no washers' include the generator front adjustment bracket too? -Dan-
          • 43247
          Dan------
          I can't say for a 1962, but for later years if there was a brace that was also attached by the waterpump bolt, then there was a lockwasher between the bolt head and the brace, but none between the brace and the waterpump. I suspect that this was the same for 1962.
          Also, for later years, if a hex-flanged stud was used for waterpump attachment and also for generator brace retention, there was no washer between the stud's hex flange and the waterpump, but there was a lockwasher between the brace and the nut installed on the outer end of the stud.
          • Dan D.
            • November 5, 2008
            • 1323
            Thats what I would have thought Joe. Thanks -Dan-
