My car just started doing this, what could it be? - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    It started this last week, when I turn the ignition switch off the car wants to run for 1-3 secs before finally cutting off.
    Sometimes it will do it most time not but it will say 1 out of 5 times after running it and turning it off.
    it did it the other day when I got my tires put on! was embarrassing.
    I would guess the timing has got off somehow and is a bit high maybe? would that be something that may cause it? Only thing I've done lately since it's been rebuilt was put new r45xls plugs in it and shielding plug wires..that wouldn't have anything to do with it just saying nothing has been messed with. So, if it is the timing not sure how it just got out like that unless the dizzy set bolt got loose.
    thoughts?
  • Keith B.
    • March 7, 2008
    • 928
    Re: My car just started doing this, what could it be?
    can you tell us what we are working with
    • Jean C.
      • June 30, 2003
      • 688
      When you turn the ignition off, is the engine dieseling or contuing to run normally?
      • Brandon T.
        • October 23, 2008
        • 872
        1. It's a 68 l36
        2. The engine is what you're referring to as dieseling, it's still running but struggling and knocking kinda like you say (diesel sound) then it will die.
        haven't had any issues since I rebuilt it and got it back on the road until now, just all the sudden started this but no other symptoms are present, it still runs fine.
        • Jean C.
          • June 30, 2003
          • 688
          Google "dieseling" or "engine run-on".
          • Dick W.
            • 10483
            What's your idle speed?
            Dick Whittington
            • Brandon T.
              • October 23, 2008
              • 872
              I seem to think it's around 650 or so.
              • Dick W.
                • 10483
                Check the manual and see what it is supposed to be. 50 rpm too much could cause your problem
                Dick Whittington
                • Brandon T.
                  • October 23, 2008
                  • 872
                  thanks, because I did just idle it up the other day justa hair! bet thats it.
                  • John D.
                    • December 1, 1979
                    • 5507
                    Brandon, It could be the crappy gas.
                    Typically I almost agree with old DW but I don't think 50 RPM would do squat. You have other issues.
                    Maybe you have an LT1 cam causing the problem. JD
                    • Brandon T.
                      • October 23, 2008
                      • 872
                      Under google it mentions plugs COULDA cause it by being too hot of a heat range.
                      would r45xls's be a possible issue here? I haven't been long put them in, maybe a month ago?
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        Well back in the OLD days 60's 70's it was quite common. Poor gas causing carbon to build up on top of the pistons .
                        Which stayed lit . We ran water or trans fluid down the Carb to clean off the carbon , some times the carbon build up was so bad you got a engine knock and people thought their rods were going. Anyone that don't remember this and using water will think I'm crazy but it worked
                        • Timothy B.
                          • April 30, 1983
                          • 5193
                          Brandon,
                          A hot spark plug has the porcelin more exposed and extended down lower to conduct heat out to the metal outer spark plug housing then to the head. They run hot and therefore keep cleaner and are less prone to foul. This heat can cause run on like you describe.
                          Take a look at a few plugs and compare the color to a chart like in your service book to see if that's a possible cause. Other problems can be caused from carbon, plug threads sticking down into the combustion chamber etc., anything that will retain heat.
                          I think that's where these idle solenoids came into play because when the ignition is turned off the throttle blades shut closed to prevent run on..
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            Plugs being too hot can act like glow plugs.
                            Stu Fox
                            • Ed D.
                              • December 1, 2003
                              • 207
                              distributor timing
