Spark Plugs - NCRS Discussion Boards
Spark Plugs
  • Ralph P.
    • February 1, 1990
    • 253
    Spark Plugs
    I know we recommend AC R45XLS plugs for 427's...... The R45S appears to have the same configuration except for a shorter thread reach. Is there any difference ...ie, reason to prefer one over the other ?
    Re: Spark Plugs
    You might have changed stroke or used piston with different dome geometry and the XLS tip extends too far into the combustion chamber for safe clearance. If this isn't the case, in general, extended tipped plugs tend to ignite the air/fuel mixture a bit more efficently due to their longer reach (more centered in the combustion chamber)...
    • Dave S.
      • August 31, 1992
      • 2926
      Re: Spark Plugs
      Ralph,
      An R45S will not work in your 427. You need an "N" plug like a 43N, 44N, 45N, R44N, R45N etc. All Big Blocks require a plug with an "N" designation. "S" is for extended tip. I'd have to check my AC Plug book to see what X and L designate.
      • Ralph P.
        • February 1, 1990
        • 253
        Re: Spark Plugs
        Dave, the R45XLS has been recommended many times on this forum as appropriate for any vintage 427 used in "normal" highway use....
        • Jeffrey S.
          • May 31, 1988
          • 1890
          Re: Spark Plugs
          Ralph:
          The XL designation is for a fully threaded, 3/4" reach plug. The "N" plugs are also 3/4" reach but only 1/2 threaded. The XL's were specified for aluminum heads like L-88, L89. They will thread into a steel head just the same. The "S" as was said is for extended tip which effectively adds a 1/2 heat range to the plug so a R45XLS would have a 5 1/2 heat range. The R45S has only a 3/8" reach and will not go into the combustion chamber of a big block.
          Jeff
          • Ralph P.
            • February 1, 1990
            • 253
            Re: Spark Plugs
            OK... that's my answer ! The shorter reach plugs won't fit a BB Thanks !
              Re: Spark Plugs
              Correct...but the R45S plugs work great in small-blocks.
