C2 1965 Front Ride Height - NCRS Discussion Boards
  • Ed D.
    • December 1, 2003
    • 207
    The front end of my 65 327/300 convertible has sat 3-4 inches too high in the front since I purchased it ten years ago ..... and I am tired of looking at it!
    I have decided to take action.... OK it took awhile
    I suspect the springs are wrong (i think 10 coils ....hard to count on the car)) and have purchased new ones from L.I.C. (12coils)
    Besides the springs what else should I look for that may cause the car to sit high ???
    Thanks for your ideas!!!!
    Re: C2 1965 Front Ride Height
    Are the springs installed upside down?
    • Ed D.
      • December 1, 2003
      • 207
      Jack, I'm not sure! To be perfectly honest ..... I didn't know there was an upside down I hadn't looked noticed it in my shop manual. Can you tell by looking at it on the car?
      • Gene M.
        • April 1, 1985
        • 4232
        Some springs have a cut notch to indicate top.
        The closer wound coils go at the top.
        • Ed D.
          • December 1, 2003
          • 207
          Thanks! ....and I thought Jack was kidding me
            Ed -
            The original #3851100 springs were variable-rate and progressively-wound, and the end with the closely-spaced coils went up, in the spring pocket in the frame, as noted in the Assembly Manual.
            I don't think any of the currently-available replacements are wound that way; all I've seen are constant-rate, with evenly-spaced coils.
            Photo of #3851100 springs below.
            • Ed D.
              • December 1, 2003
              • 207
              Ed -
              John .... Thanks for the pics!! That will help a lot
              .......Ed
              • Ed D.
                • December 1, 2003
                • 207
                Re: ++Springs correct++ 1965 Front Ride Height
                John... Jack ... ??
                Springs are progressive and sitting in the correct position. No spacers.
                Any other ideas why the front end sits up 3 or 4 inches too high
                ...Ed
                • Joe C.
                  • August 31, 1999
                  • 4598
                  I have searched ebay and see some 3851100 "NOS" springs for sale. All I have seen are with 12 coils, non progressive.
                  Hinckley posted a photo of the springs as originally configured.
                  If your springs are not nestled with its ends butting directly the ends of the spring pockets, then your car will sit too high.
                  • Ed D.
                    • December 1, 2003
                    • 207
                    Thanks again Joe!!
                    • Gary B.
                      • February 1, 1997
                      • 7041
                      Mid-year standard coil springs; 10 vs 12 coils
                      Guys,
                      Something's fishy here. The original, progressive coil springs that I removed from my '66 L79 with standard suspension have 12 coils not 10. I can measure the length if anyone is interested, but these springs are original with the (unreadable) ID tags still on them and they absolutely have two more coils than the ones in John's photo.
                      Gary
                      • Joe C.
                        • August 31, 1999
                        • 4598
                        Re: Mid-year standard coil springs; 10 vs 12 coils
                        Originally posted by Gary Beaupre (28818)
                        Guys,
                        Gary
                        Gary,
                        The original springs that I removed from my 1965 327/365 without C60 are as pictured in John H's photo. The new 3851100 springs which I bought from a local Chevrolet dealer in 2000, are the same.
                        • Bill M.
                          • April 1, 1977
                          • 1386
                          Guys,
                          Gary
                          I count 12 also...
                          • Mike G.
                            • January 1, 1991
                            • 418
                            swaybar link
                            I've seen swaybar link kits that have LONG spacer tubes, which can add a few inches to the ride height.
                            Check your spacers to see if they're ~1.75" long.
                            BTW, my '65/300 is 24" at the nose beltline.
                            • Gary B.
                              • February 1, 1997
                              • 7041
                              3851100 springs; I believe 12 coils is correct, not 10
                              Ed -
                              John,
                              In a posting on Sept 3 of 2007 Joe Lucia stated:
                              On November 10 of 2007 Jerry Fuccillo posted a photo (attached) of the original springs on his '67 base engine car with tags have 3851100 ED, clearly showing 12 coils. The 12-coil springs in Jerry's photo are identical to the original springs on my '66.
                              Gary
