Greetings to all and attention to those with 65 AO Smith cars. I have an unusual finding to present to you for your consideration. Both of my doors on my personal 65 AO Smith convertible have bolts holding the inner steel structure to the door frame on what I believe - except for sanding and repainting red - are untouched doors. (This is a nearly no-hit body and a very well preserved Corvette). The forward bolts would be virtually inaccessible without removing the door skin from the door, which has not been done post assembly line construction. The bolt head marking is unlike any hardware store or shop supply bolt I've seen, but then so is that fact that these two doors have bolts instead of assembly rivets. The areas with the bolts have been plastic-media blasted to answer my question as to whether or not any work has been done in this area, and it has not. There has not been a wrench taken to the opener bolts nor have the inspection covers ever been removed. I don't think I've seen the wide masking tape on an inner door totally intact before. The point is; these doors are built the same way and have never been damaged, or apart in my opinion. My thought is that maybe the line in Iona MI was running short on assembly rivets in April '65 and "rationed" them by installing bolts to the doors where they could get away with it, keeping the line moving. Again, the forward bolts are not accessible with the door skin in place, so I believe this was done at the assembly level.
I wanted to post this to see if this anomaly has shown up on anyone else's doors. The door fiberglass is dated Mar 65; the body was assembled APR 19 65 and the final assembly of my car was APR 27 65. I would appreciate it if you would direct any freinds with APR 65 cars to this discussion. Thoughts? Thanks for your time. -Jeff
