68 odometer - NCRS Discussion Boards
68 odometer
  • Steven H.
    • May 26, 2009
    • 13
    68 odometer
    My 68 speedometer works, but the odometer is stuck on "0". Any ideas on what the problem probably is? Thanks.
    Steve Ham
    • 43289
    Re: 68 odometer
    Steve Ham
    Steve-----
    Most likely the gear that drives the odometer from the speedometer is stripped. In any event, it's a problem internal to the instrument. If the instrument has never been serviced or if it's been a long time, your best bet might be to remove it and send it off to a qualified instrument repair facility.
    • Michael W.
      • April 1, 1997
      • 4290
      Re: 68 odometer
      If you mean the resettable tripmeter, probably the reset cable is stuck in the 'up' position.
        Re: 68 odometer
        Mike makes a good point! The trip reset cable is spring loaded to 'snap' back to the fully extended and tripometer engaged position. Lack of use (periodic exercise) can result in a 'sticky' reset cable.
        BEWARE! If the reset cable winds up 'in between' its engaged and un-engaged positions (fully IN/fully OUT), you can generate gear 'clash' that'll burn the teeth on the drive gear and result in a speedo head rebuild...
