odometer & Tripometer - NCRS Discussion Boards
  • Scott S.
    • September 11, 2009
    • 1961
    Re: odometer & Tripometer
    Scott -
    Those item #22 U-nuts go in each "window" opening in the lower windshield frame, and accept the #23 bolts that attach the main dash panel; the U-nuts can't be seen with the main dash panel installed, as its front flange covers the lower windshield frame (except at the openings for the lower garnish molding nut locations - 1Asm, F19, View A).
    [ATTACH=CONFIG]36749[/ATTACH][ATTACH=CONFIG]36750[/ATTACH]
    John,
    Thank you for the pictures and the explanation, I understand now,
    Scott
