This question has come up time and time again and I do not have the answer.
59 FI car with a 7017300 unit on it. For those of you that don't know the '7300 unit started off life as a 57 FI. Therefore the "choke" wiring harness is identical to a '57.
But a typical repro '59 engine starting harness has no provision to plug in the '7300 57 style wiring harness.
What's a fellow to do?
Now if you had a '59 FI car that used various other FI models you would have no problem as the choke wire-1 wire- would just go to the 12V side of ballast resistor.
Anyone have an original wiring harness or an original '59 Fi car with a '7300 unit on it? Thanks, JD
P.S. I have told a few people to buy a '57 FI wiring harness. But I was wrong as they won't fit the '59
