Re: Crane Cams is BACK!!!
[quote=Gene Manno (8571);476244]Widening the LSA by itself has a negligible effect on reducing cylinder pressure, unless it results in a later closing of the intake valve. For example, if you begin with a cam ground at 110 LSA, and installed at 110 degrees (0 degrees advanced,110/110/110, or "straight up)), take that same cam and widen the LSA to 114, and install that cam at 110/114/118, or 4 degrees advanced, then the cylinder pressure will not change to any great extent, unless you consider the effect of the now retarded exhaust valve timing.
In Duke's example, the slight advance of the ICL will increase cylinder pressure ever so slightly, and so will provide a hairline less detonation resistance. The wider LSA will decrease overlap, thereby increasing idle vacuum and boosting low/midrange torque.
In general, wider LSA's are better suited to smaller displacement engines, while narrower LSA's are better tolerated by larger engines, all other things being equal...................
