Don't go away just yet even though this has been discussed before. I want to use drive in plugs or tap and use NPT pipe plugs to block my '67 300 hp hot slot holes while intake manifold is on engine. Problem is, can't find a Dorman drive in plug or pipe plug of correct size. The 1/4"threaded pipe plugs(this size pipe plug is actually 1/2" or slightly larger in size) requires a tap too large to use without drilling and drive in plugs are too small or too large.Has anyone had this problem and found a solution? Does anyone have a special gasket or right size plugs(my hole is minimally smaller than 1/2") that I could buy?
Bill Ford
Bill Ford
