Original horns on a '57 - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    Does anyone have good e-pictures of original '57 horns.....? Also.... what are the part #'s for these items and are these numbers visible when viewing the horns installed in the car?
    I realize this information is probably in the newly-updated JG, but I don't have a copy of it at this time..... Thanks
    Garry Eastwood
    #38705
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Original horns on a '57
    Left horn #760 right #759 and vin 1500 changed to Right #339 and left #340 the bracket holes location are different then a car bracket. If you see a horn laying on the ground all 12V will have a RED plastic insulator while 6V will be WHITE. That's just some trivia
    • Gary C.
      Administrator
      • October 1, 1982
      • 17769
      339/340 horn photos Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Garry E.
        • 240
        Gary/Roy....
        Now I'm really confused...!! The two sets of horns pictured in each of your replies are considerably different..... I'm looking at a car with a build # of ~3100 and a build date of early April, '57..... Which of these two sets of horns would be correct for this car?
        Thanks for your help.....
        Garry Eastwood
        #38705
        • Gary C.
          Administrator
          • October 1, 1982
          • 17769
          Garry, just as Roy's post said "above VIN 1500~" would have the 339/340 style horns which are the photos I posted. Roy's photos are for the 56 and early 57 horns. Recommend you order a 5th Edition 56-7 Judging Manual as it's quite and update and has many photos in it. Gary....
          NCRS Texas Chapter
          • Garry E.
            • 240
            Gary:
            Thanks for the clarification......If I end up getting this car, the first thing I will be buying will be the new JG..... I leafed through it down at the FL Regional..... you guys did a great job on it......
            Garry Eastwood
            #38705
            • Tom P.
              • April 1, 1980
              • 1815
              As mentioned, those pictured by Roy are 56-early 57 style.
              BUT, just for informational purposes, the horns on 53-54 PASSENGER cars are the same configuration--------------EXCEPT they are 6volt.
              I have the 6v pass car horns on my 56 (the appearance is identical to the 12v Vette horns). TRUST ME, when I tap the horn, and put 12v to those 6v horns, it gets peoples' attention!!! I love 'um!
              I also have the original 6v horns on my 51 Chevy which has been converted to a 12v system. Same effect!
