'61 Door Putty - NCRS Discussion Boards
'61 Door Putty
  • Richard P.
    • July 31, 2001
    • 173
    '61 Door Putty
    What type of putty is used on '61 door to hide the adjuster bolt below the door pillar? I assume it is painted the body color?
  • Edward L.
    • 278
    Re: '61 Door Putty
    Personally, I don't believe putty was used to conceal the door post adjuster bolt. Every car I've ever taken apart required a die grinder to remove what I'm sure was resin.
    However, without getting into that, the putty or "dum dum" can be purhased at plumber supply stores or Home Depot. I use 3M strip caulk. It comes in white and black.
    The area received a brush applied application of body color paint. Often there is evidence of a small amount of paint on the weatherstrip adjacent to the filled area.
    Ed
    • Ray C.
      • June 30, 2001
      • 1132
      Re: '61 Door Putty
      I believe it was bonding adhesive.
      Ray
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
      • Mike E.
        • February 28, 1975
        • 5138
        Re: '61 Door Putty
        First there was putty (dum-dum) that covered the adjusting bolt almost to the level of the area surrounding the hole. Then a resin-like hardening material was spread over the top of that. It was then hand touched-up with body color.
        • Steven B.
          • June 30, 1982
          • 3988
          Re: '61 Door Putty
          Mike, what years was this done?
          Thanks!
          Steve
