C2 Front License Plate mounting - NCRS Discussion Boards
  • Blake W.
    • April 30, 2001
    • 164
    Is the front license plate bracket mounted (or orientated) so that the plate sets high or low relative to the cross bar? Seems that if mounted so that it sets high then airflow to the radiator would be restricted more so than the other (low) position.
  • Chris E.
    • November 3, 2006
    • 1331
    Re: C2 Front License Plate mounting
    The chrome license plate bar should cut basically right through the middle of the plate.
    Chris Enstrom
    2011 Z06, red/red
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Blake,
      the bracket bolts under the crossbar from the bottom, nutted on top.
      We have seen them incorrectly on top, and yes, even upside down. So, the stamped out opening with the "ds" stamp on the reverse side is oriented to the top above the bar.
      HaND
      • Blake W.
        • April 30, 2001
        • 164
        Thanks Chris and Mike. It was installed just as you both have described. That was an easy one. Reguards, Blake
