1964 Build date - NCRS Discussion Boards
1964 Build date
  • Dan P.
    • December 1, 1990
    • 683
    1964 Build date
    car 121357 according to the birthday book was built on July 8 the trim tag says F25 does F 25 mean Febraury 25 ? thanks
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1964 Build date
    No --- F, for 1964 Smith bodies means June. A was January, when they first started Corvette body production there. Trim tag will also show A-xxxx for the body number.
    • Dan P.
      • December 1, 1990
      • 683
      Re: 1964 Build date
      Thanks I am trying to date a set of shocks for the owner and he thought the car was built February 25.
      • Larry M.
        • January 1, 1992
        • 2702
        Re: 1964 Build date
        Dan:
        If the car BODY is St Louis built, then F is February 1964. However, if the car BODY was built by AOS, then F is June 1964. When AOS began building bodies at the beginning of 1964, they started with the letter A.
        I would expect #21,357 is an AOS body car. The BODY number should also begin with an A-xxx and the font is 1-1/2 or double space, which is unique. St Louis TRIM TAGS are single space.
        Larry
