65 Intake Question - NCRS Discussion Boards
65 Intake Question
  • William L.
    • February 18, 2010
    • 22
    65 Intake Question
    I have a 65 250HP coupe built Jan 65 and am trying to determine the correct intake manifold numbers. The intake on the car is 3866922 with a J274. Could this be the original intake as most other numbers are correct. If not, what number intake and date should I be looking for? Thanks for any information from a new member...............
    Bill Lutter (51430)
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 Intake Question
    Originally posted by William Lutter (51430)
    I have a 65 250HP coupe built Jan 65 and am trying to determine the correct intake manifold numbers. The intake on the car is 3866922 with a J274. Could this be the original intake as most other numbers are correct....(51430)
    Bill -- per the '65 Tech Manual and Judging Guide, yes, the 3866922*(with an asterisk) is considered an [acceptable alternate manifold]* (to 3844457) for judging purposes. By the way -- '65 owners are especially welcome .
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Hi Bill
      The date works as well.
      It may seem a bit early, however, as the base engine manifolds were batched in larger numbers that some of the others, you should be good to go.
      HaND
