Dulling down door opens and hood surround - NCRS Discussion Boards
    • 6950
    Spring is just around the cornor and I will be having my 72 flite judged for the first time.I presently have a base coat clear coat finish. I would like to salvage some of the paint points,
    What exactly will I have to dull down to get points? I know the hood surround, door opening,does this include the door also? what else?
    My plan is to use 1500 grit paper,if something else has worked for you I would like to hear about. Thanks Ed.
  • William C.
    • July 15, 2009
    • 239
    Re: Dulling down door opens and hood surround
    I used a satin clear and still lost 9 points for over restoration.
    • Sander B.
      • March 1, 2005
      • 499
      Hi Edward
      go for Scotch Brite Gold (ts similar to P2500 sand paper)
      regards Sander
      • Chuck S.
        • April 1, 1992
        • 4668
        ...What exactly will I have to dull down to get points? I know the hood surround, door opening,does this include the door also? what else?...
        Imagine that, instead of glossy BC/CC, you had mistakenly painted the car with a flat paint with absolutely zero gloss (*&$%#@). BUT...the good news is that when you use a power buffer and compound on the flat finish, it shines up beautifully, somewhat like CC.
        Now, imagine polishing the entire car with the buffer without opening any doors, hood, headlights, convertible deck, removing the T-tops, removing trim items etc...Those areas that would remain untouched by the buffer wheel are the same areas where you need to reduce the gloss on the CC.
        I can't imagine exterior judges using any other formula. Edit: If they're looking for anything less than what I've described, only that judge will able to tell you what areas he expects to see low gloss.
        BTW, I'm with Sander, 1500 grit paper will be pretty aggressive for this task. I haven't tried the scotch brite for that purpose, but as a painter, I expect Sander knows what unpolished acrylic lacquer looks like. Scotch brite is graded by color...that's where the "gold" comes from.
        • Patrick T.
          • September 30, 1999
          • 1286
          I used ColorRite clear spray lacquer and it looks perfect, just the way judges want to see. The good thing is that you don't permanently screw up the paint job. If you don't want to look that way later, it comes right off with a cloth and lacquer thinner. I had my car flight judged last October and got zero deduct for the paint. You need to call their Pa. shop to get the lacquer since you can't buy it in Calif. PT
          Sorry, the page you are looking for cannot be found. Please check the URL and try again.
          • Jim R.
            • June 30, 2001
            • 643
            3M makes a dulling agent product that comes in a small bottle similar to a wax bottle that works awesome you just put some on a rag and rub it on and it dulls the paint without leaving any marks like sanding will.
            • Kenneth T.
              • March 23, 2008
              • 631
              Hey Jim,
              Is the process reversible or permanent?
              Thanks, Ken
                • 6950
                Chuck,Sander,are the scotch pads avaliable at like the home depot , or is this strickly automotive paint supplys?
                Chuck, I have a good feel as to the exterior is suppose to look like but I not willing to touch the exterior of car other than only whats needed to, if possiable to salvage some of the points that required by dulling down the only whats absolutly necc.
                I know that no two judges will be on the same page when it comes to judging the paint on any given car. so my approach will be only to do whats only necc. to achive some of the points.
                So what do you recommend fot the dulling down areas. thanks to all who have responded. Ed
                • Jim D.
                  • 2885
                  I've heard spraying the jambs with hair spray works. The nice thing is that it's temporary. Once judged, you can wash it off and again, have a beautiful paint job.
                  • David S.
                    • August 9, 2009
                    • 595
                    Do you know what product that is?
                    Dave
                    • Dick W.
                      • 10483
                      If the judges follow the judging guidelines, the point deductions should be the same
                      Dick Whittington
                      • Jim D.
                        • 2885
                        Sure, right.
                        • Dick W.
                          • 10483
                          Originally posted by Jim Durham (8797)
                          Sure, right.
                          Several month, years, ago, there were standard deductions issued for paint. Same principal as the engine. If you pass A, go to B, etc. I think someone on this forum posted them some time ago.
                          The standard guidelines take the personal opinions out of paint judging.
                          Dick Whittington
                          • Jim R.
                            • June 30, 2001
                            • 643
                            Dave and Ken yes it is reversable you can just polish it back. and i will get back to you with the 3m part# i will send you a pm. jim
                            • Chuck G.
                              • May 31, 1982
                              • 2038
                              That's what I did with my 63, which is painted in single stage urethane (Riverside Red).
                              I'm curious about this 3M "dulling agent" product.
                              IMHO, sanding the jambs, gutters, etc. makes the car TOO dull.
                              Lacquer was shiny when applied. Those areas just were not buffed.
                              Try shooting some gloss Krylon or Rustoleum on a piece of metal or fiberglass. Let it dry. See how shiny it is, without buffing.
                              Chuck
