muncie problem - NCRS Discussion Boards
muncie problem
    Infrequent User
    • December 23, 2009
    • 14
    muncie problem
    Hello
    I am having problems when going to 4th gear, it is very hard to shift into 4th. It is fine going into the other 3 gears. I pulled off the shifter arms and tried, it is the same from below with using a wrench on the arms, so this eliminates the shifter. Any ideas, I will have to pull the tranny I guess and the side cover to see if anything is wrong inside.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: muncie problem
    If just sitting in the driveway with the engine running, will it shift to 4th OK?
      Infrequent User
      • December 23, 2009
      • 14
      Re: muncie problem
      No it is very hard to go into 4th, will go but really hard. Its not the shifter, as I disconected it and was the same when under the car using a wrench on the arms. Its a 65 M20
        • 43281
        Re: muncie problem
        Terry------
        There's got be some sort of internal problem, most likely with the input shaft (4th gear) synchro.
