1959 T10 Transmission color question - NCRS Discussion Boards
  • Chuck M.
    • February 1, 2002
    • 335
    Can anyone tell me the original/correct color scheme for a early 1959 T10 tranny? I believe the main case is black, the tail housing and inspection cover are silver/aluminum, the linkages are silver, and the shifter bottomworks (linkage pegs) silver. Thanks for the help. Any pics would be great! Dated 3-23-59
    Chuck
  • Mike M.
    • May 31, 1974
    • 8382
    Re: 1959 T10 Transmission color question
    i leave the cast iron case in its raw cast appearance. the intermediate plate and tailhousing are left raw aluminum. the shifter and its rods are black oxide. mike
    • Richard H.
      • March 1, 1985
      • 241
      If you email me I will send you pictures of an original 1959 t-10 that was restored by Darrell at Pipers to proper specs. I'm not sure how to attach pictures to this site. Richard
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12737
        This is how mine looks like:
        regards,
        Rob.
        Rob.
        NCRS Software Developer
        • Sid C.
          • September 6, 2010
          • 1
          If this is a correct photo then why does the engine have aluminum valve covers?
          I thought that the single carb engine had stamped steel painted valve covers?
            • 43219
            Sid------
            You're correct. The 1959 single four barrel engine did not originally use aluminum valve covers. However, I suspect it was not Rob's intention to say that EVERYTHING in the photo represented correct configuration----just the transmission which is the subject of this thread.
            A lot of folks install the aluminum valve covers on a Corvette engine that did not originally use them. It's pretty easy to change them out for judged events.
