Type 3 Jack Question - NCRS Discussion Boards
  • Harvey S.
    Infrequent User
    • May 31, 1999
    • 24
    Hi Guys:
    I am restoring my Type 3 jack and I am not sure if the the steel washers and nylon washer are original.
    I am looking for the specific dimensions of the both the steel and nylon washers. Are both steel washers the same thickness? What is the thickness and diameter of the nylon washers?
    I searched the archives but did not find the requested information.
    Thank you
    1966 427/450 Coupe
    Duntov Award
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Type 3 Jack Question
    Harvey, My type three has both steel washers at .100 thick and 1.320 diameter. Nylon washer is .125 thick and 1 inch in diameter. Hope that helps. Russ
    • Harvey S.
      Infrequent User
      • May 31, 1999
      • 24
      Thanks Russ. Much appreciated.
      1966 427/450 Coupe
      Duntov Award
