Holley 2818-1 question - NCRS Discussion Boards
  • Joseph K.
    • March 1, 1980
    • 168
    This carb is original to my 65, with that said when i tried to start car a loud backfire and when I looked into the carb throat the drivers side primary? has deformed as if it where very hot!! Can this be repaired and if so who should I look too? thanks for any help.........Kirby
    Re: Holley 2818-1 question
    Try Eric Jackson at www.vintagemusclecarparts.com; he's a top-notch Holley restorer.
    • Joseph K.
      • March 1, 1980
      • 168
      Thank you John!!.....................Kirby
      • Michael M.
        • June 30, 1997
        • 97
        Holley has a restoration shop at the factory (Check there web site). I had them do my Holley off my 67 SB. Have not used it yet, however they still make parts for the old Holley Carbs.
        Also check these people www.customrebuiltcarbs.com they did some work for me for another vette and have had others get carbs done there and all have been very satisfied with the finish and function. Carb can be rebuilt to street use or show, which ever you want and they flow test the carb and set to original specs. I bolted my carb back on and started the car with out needing an adjustment. Looked brand new, with proper color and finish also.
        Both restorations were about $500.
        Good Luck.
