56 fuel filter to carb connection - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    OK, what type of tube is used to connect the carburetor to the fuel filter (the glass bowl type)? This would be for a single four application if it matters.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 56 fuel filter to carb connection
    I would say about 1 1/2 brass pipe
    • Edward M.
      • November 1, 1985
      • 1922
      Brass pipe, 1 1/2 inches long? Is that what you are saying?
      • Roy B.
        • February 1, 1975
        • 7044
        Yes round pipe type , it's just so long so that when you start one end into the Carb and filter at the same time you can tighten them with out the filter touching the Carb. Same as my 55 , 57 should be the same ! Guessing on how long that is!
        • Edward M.
          • November 1, 1985
          • 1922
          Cool, thanks.
          • David S.
            • December 1, 1982
            • 310
            Hi Ed,
            I guess I did not see your post before.
            Attaching a picture of the nipple on my 57 bowtie 220 HP 1x4
            Dave
