63 Bypass/Exp Tank Clamps - NCRS Discussion Boards
  • Jeff Z.
    • January 31, 1994
    • 94
    Trying to determine if water pump bypass, expansion tank to tee and expansion tank to radiator clamps are original in below pics. Part #s 274337 and 111607 in AIM 11-13/8. Car had the same clamps for bypass and tee. Since L76/L84 sections don't list this part number not sure what's correct. Also included is pic of hose from expansion tank to radiator. Not sure if original. Can someone please educate me on clamp details?
    Jeff
    63 Convert 340 hp
    66 Coupe 300 hp
    67 Camaro 1500 hp
    00 SS Camaro 320 hp
    Director Region V
    • August 31, 1994
    • 1463
    Re: 63 Bypass/Exp Tank Clamps
    Well, Jeff, since no one seems interested, I'll kick it off for you.
    I don't have a '63-4 AIM, however, the schematic in the '63-4 JG clearly shows this style clamp in those positions. The '65-6 & 7 AIM's show the same configuration and part numbers. This appears to be a consistant application throughout M-Y production, although, the screw head configuration did change between the years, which may or may not effect the PN's.
    This may prompt others to contribute more specifics if needed.
    Nice hose, especially with the "Alligator Hyde" pattern.
    HaND
    • John D.
      • November 30, 1979
      • 5507
      Jeff, Very nice original clamps. When I look at various restored cars you don't typically see the correct clamps. Now your pic is quite dark though. Would really like to see a side view if possible.
      The water pump bypass hose clamps are all on their own also.
      Maybe Jorjorian will chirp in as he taught me about these clamps. JD
      • Jeff Z.
        • January 31, 1994
        • 94
        John here is hopefully better pic. Two clamps are off my 63 and 3rd clamp is 60s pass car that shows variations in design/manufacturing. All clamps are stamped A4 1/2. My 63 had same clamps on bypass as expansion tank to tee. These hoses have all been replaced so I can't verify originality of clamps. This particular car has been sitting since 1972 so there are a lot of untouched items.
        Jeff
        63 Convert 340 hp
        66 Coupe 300 hp
        67 Camaro 1500 hp
        00 SS Camaro 320 hp
        • Bob J.
          • November 30, 1977
          • 713
          Jeff
          Jeff, your A 4 1/2 look correct for 63 expansion T . The bypass clamps are same but larger size at A 4 3/4.Bob
