1967 fan clutch - NCRS Discussion Boards
1967 fan clutch
  • Jeremy H.
    • January 1, 1999
    • 260
    1967 fan clutch
    Who sell the correct looking eaton fan clutch? The one thru Napa doesn't look correct. I know there is one that only looses a few points.
    Jeremy Hedges
    #31711
    • 43247
    Re: 1967 fan clutch
    Jeremy Hedges
    #31711
    Jeremy-------
    GM #3916141. Available from GM or most of the Corvette parts suppliers like Dr. Rebuild, Paragon, etc. It carries a GM list of about 275 bucks at the present time.
    • David L.
      • July 31, 1980
      • 3310
      Re: 1967 fan clutch
      Jeremy Hedges
      #31711
      Jeremy,
      I found this NOS 6" dia. fan-clutch for cheap money ($10) at Fall Carlisle 2009. It is the closest match to the coil type fan-clutches that were made in the early and mid 1960's that I have ever seen. The bolt circle on the hub measures 1.75". The front face is ink stamped "FC-16" and "H28J" (possibly August 28, 1979). This fan-clutch has 2 "small ears" on its face. The coil type fan-clutches made starting about 1969 or so have 2 "large ears". One problem with this fan-clutch is that it will only fit fans with a 3.25" bolt circle. It will not fit on a 61-67 Corvette fan with the 3.00" bolt circle. Another problem with this fan-clutch is that the shaft is about 0.42" too long, I think. The measurement from the water pump mounting surface to the fan mounting surface is about 2.20". This same measurement on my original 1966 Corvette (Schwitzer type w/ bar strip) fan-clutch dated "SC 1 26 66" is about 1.78".
      Dave
      • Joel F.
        • April 30, 2004
        • 659
        Re: 1967 fan clutch
        Jeremy,
        this is the fan clutch you are looking for.
        • David L.
          • July 31, 1980
          • 3310
          Re: 1967 fan clutch
          The NORS (not NOS) 3916141 fan-clutch in the Ebay auction for $175 is a replacement. This fan-clutch has the "large ears" on the face side which did NOT exist in 1967. If I was a NCRS judge I certainly would notice that it was not original equipment. Maybe some of the "rookie" NCRS judges would not notice. You can always spend $175 and hope.
          • Joel F.
            • April 30, 2004
            • 659
            Re: 1967 fan clutch
            Good points David, but I believe he is looking for the replacement as he said he knows it will lose a few points.
              Re: 1967 fan clutch
              GMPartsDirect.com has them for about $160.00 (plus shipping).
              • John D.
                • June 30, 1991
                • 875
                Re: 1967 fan clutch
                John,
                The GM cost went up to $157.28 as of 3/1/10. So the partsdirect website is very close to dealer cost on the price. If I remember correctly the ebay seller used to have the best price on these around $100 or so...don't know what happened there.
                  • 43247
                  Re: 1967 fan clutch
                  David------
                  The GM #3916141 was a 1968 model year released part. The original version of it had the "small" reservoir extensions (ears). Somewhere along the way, its configuration was changed in several ways, including the reservoir extensions.
                  While the current 3916141 is not exactly correct, it's as close as one can get in a NEW fan clutch for 1960-1970 Corvettes. The only other options are NOS or restored original. For a driver which is also entered into NCRS judging, I highly recommend the 3916141.
                  • David L.
                    • July 31, 1980
                    • 3310
                    Re: 1967 fan clutch
                    David------
                    Joe,
                    Actually the 3916141 fan appears in my 1967 Chevrolet Parts Catalog (effective April 1967) for a 67 PASS. (Air Cond., fan drive)(6 cyl.) and 67 PASS. (396)(427). As far as I know it was only used as a REPLACEMENT for the Corvette models, never original equipment on any Corvette model year.
                    I agree with you that it is the most practical fan-clutch to use.
                    Dave
                      • 43247
                      Re: 1967 fan clutch
                      Joe,
                      Dave
                      Dave------
                      Yes, it was definitely released in late 1967. I thought this was for the 1968 model year, but I didn't check it. I now see that it was cataloged for 1967 application. It must have been a very late use, though.
                      I believe it was used in PRODUCTION, though, for Corvettes during the 68-69 period, although its use may have been limited to L-88/ZL-1. It later became the SERVICE fan clutch for all 1960-70 Corvette applications.
                      • David L.
                        • July 31, 1980
                        • 3310
                        Re: 1967 fan clutch
                        Dave------
                        Joe,
                        According to the 68 & 69 Corvette assembly manuals the L36, L71, and L88 used a 3937771 fan-clutch. However, I have in my notes that the 68-T-9 Chevrolet Technical Service Bulletin (dated 12/27/67) shows the 3857530 & 3857531 fan-clutches to be used.
                        The 66 & 67 Corvette assembly manuals do not list a part number for the 427 fan-clutch but my 1967 Chevrolet Parts Catalog lists GM # 3857530 as the fan-clutch for the 66-67 Corvette (427).
                        My 1968 Chevrolet Parts Catalog (Oct. 67) does NOT list a fan-clutch for the 68 Corvette (427) but my 1969 Chevrolet Parts Catalog (Oct. 68) does list GM #3916141 for the 68-69 Corvette (427)(exc. C.A.C.) and GM # 3857531 (stamped CT) for the 66-67 Corvette (427), 68 Corvette w/C.A.C.(427)(exc. 3X2).
                        My 1969 Corvette Parts Catalog (Sept. 69) lists GM #3916141 (stamped CK) for the 68 Corvette w/H/Per.(427)(1st design)(exc. C.A.C., 3X2), 68 Corvette w/Sp.H/Per (427)(1st design), 68-69 Corvette w/H.D.(427). It also lists GM #3937771 for the 68-69 Corvette w/H/per.(427)(2nd design)(exc. 3x2), 68-69 Corvette w/Sp. H/Per. (427)(2nd design), 68-69 Corvette w/C.A.C.(exc. 427 w/4BC), 69 Corvette w/H/Per.(350), 69 Corvertte w/A.T.,H.D. (427).
                        So, the 3937771 fan-clutch as shown in the 68-69 assembly manuals does make an appearance in the Sept. 69 parts catalog.
                        It's a bit confusing but you might be right about the 3916141 fan-clutch being used on the production line as a "1st design" fan-clutch, I think, but I am not 100% sure.
                        Well, I think we beat this topic to death.
                        Dave
