57 Grill Bar Question - NCRS Discussion Boards
  • Ashley S.
    • November 1, 2005
    • 146
    Can anyone show or describe to me the correct orientation of the (5) bars that hold the grill bar into the grill oval? Mine are not symmetrical, so I'm guessing there is an up and down direction for the bars. Any help is appreciated.
    Ashley
  • Gary C.
    Administrator
    • October 1, 1982
    • 17915
    Re: 57 Grill Bar Question
    Ashley, take a look at Corvette Central's illustrations and see if that helps. Gary....
    http://www.parts123.com/parts123/yb.dll?parta~showpic~Z5Z5Z50000050e~Z5Z5Z5PD7K~Z5Z 5Z52~Z5Z5Z5~Z5Z5Z5
    http://www.parts123.com/parts123/yb.dll?parta~showpic~Z5Z5Z50000050e~Z5Z5Z5PD7K~Z5Z 5Z5~Z5Z5Z5~Z5Z5Z5
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Roy B.
      • February 1, 1975
      • 7044
      If you put them on up-side-down you'll be the first to know
      • Ashley S.
        • November 1, 2005
        • 146
        Thanks Gary and Roy. I got it in last night. I'm not 100% sure I'm right, but it seems to look ok.
        Ashley
        • Gary C.
          Administrator
          • October 1, 1982
          • 17915
          Ashley, you should have uniform fitting teeth spacing from the oval on both top and top. About 1/2" or be able to slip fingers between the teeth and the oval. Gary....
          NCRS Texas Chapter
