LS2 Crate Engine - NCRS Discussion Boards
LS2 Crate Engine
  • Dick G.
    • May 31, 1988
    • 681
    LS2 Crate Engine
    I bought an LS2 crate engine from a Chevrolet dealer. She has a Cadillac oil pan with a complete clutch assembly. Does anyone know, Did Cadillac's have a manual transmission as an option? Which model of Cadillac? This is a LUK clutch assembly. What other cars came with these clutch assemblies? I know sometimes that GM simply assembles engines to use up discontinued parts that all interchange together. Is this the case? I saw this on an LS6 crate engine recently while hunting for the LS2 engine. I know a chevrolet dealer who has a pile of LS6 crate engines. The ones I saw had Cadillac CTS pans. I now need to find a corvette LS oil pan, and sell my Cadillac pan and clutch.
    DG
  • James W.
    • December 1, 1986
    • 278
    Re: LS2 Crate Engine
    Te CST-V came with a 6-speed manual. The LUK was used on Corvettes, maybe other cars. To find an oil pan go to one of the Corvette recyclers. I would go to Corveet forums and check the vendors there. Quite a few active recyclers
    Jim
      • 43221
      DG
      Dick-------
      What is the part number of this crate engine assembly? If it happens to be 19165484 it's not a Cadillac pan. That LS2 engine assembly is equipped with a Corvette wet sump pan. If it's some other part number, what makes you think that it's a Cadillac pan installed on it?
