Missing something here, ground lugs and where they're supposed to go are not reaching - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I know I have the right length wires on the right cylinder, no question there.
    on the passenger side I have cylinder wire lugs for cylinder 2 & 4 on the first valve cover bolt from the front and it reaches but is tight.
    I have cylidner wire ground lugs for cylinder 6 & 8 on the 3rd bolt and they look fine.
    on the driver side, cylinder wire ground lugs for cylinder 1 & 3 the #3 cylinder wire won't reach the first valve cover bolt from the front so I put them under the 2nd valve cover bolt from the front is this correct???????
    then I put cylinder wire ground lugs for cylinder 5 & 7 under the rear/last valve cover bolt..
    is this correct or no the aim is a hunk of junk on this one and I see pictures that vary from car to car..what is correct?
    this is on my 68 l36, thanks
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Missing something here, ground lugs and where they're supposed to go are not reac
    Brandon, the gounds don't go on the first v/c bolt, it's the second and forth on the drivers side.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Brandon T.
      • October 23, 2008
      • 872
      Great! I was one T person when I thought the wires were bad repros!
      here she is, thanks for the help so nice to have things done right with the help of the forum.
        • 6948
        Brandon, everything looks neat and in place nice job. the hours spent on the engine and compartment shows.
