'61 Front Bumper - NCRS Discussion Boards
'61 Front Bumper
+ More Options
Posts
  • Richard P.
    • July 31, 2001
    • 173
    '61 Front Bumper
    The front bumper on my '61 does not fit right. The right side sticks out further than the left. When I removed the bumper, the Right Front bumper brace sticks out about 1/2" more than the left (the left one is flush). Anyway to adjust this? I don't know if it is the correct brace, and it appears to be mounted correctly, and but it doesn't look like it has been damaged.
  • John F.
    • March 23, 2008
    • 2415
    Re: '61 Front Bumper
    I would loosen up the bolts where attached to the frame to se if you have wiggle room, then try to tap the bumper back a little with a rubber mallet. Careful not to ding the bumper, then re-tighten the bolts.
    John
    • Terry D.
      • May 31, 1987
      • 2696
      The 58-60 brackets are different from 61 and 62. Are ya sure you have the right one? Also have you checked to make sure the frame isn't bent? Lots of things happen to 50 year old cars.
      • Rick C.
        • March 1, 1986
        • 183
        Terry,
        I think the 58-60 and 61-61 BUMPER brackets are the same, aren't they? It's the license plate frame brackets that are different.
        Rick
        • Gary H.
          Infrequent User
          • September 30, 1990
          • 25
          All the catalogs show the same bracket for 58-62, but Terry may be right because on two different cars, a 61 and a 62, I had to cut a 1/2 inch out of one bracket and weld them back together. Gary
          • Terry D.
            • May 31, 1987
            • 2696
            I stand corrected, the brackets are the same, it's the bumpers and the number of spacers used that is different. Sometimes the old brain doesn't remember thing correctly.
