Where does this bracket go? pic inside. - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    bought this bracket from paragon, aim doesn't show it. This is for a 68 l36.
    thanks!
    http://www.corvette-paragon.com/p-34...e-bracket.aspx
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Where does this bracket go? pic inside.
    Rt. side valve cover, second bolt from the front.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Brandon T.
      • October 23, 2008
      • 872
      thanks, and is this supposed to be on a 68 l36? reason I ask a lot of well detailed 68's such as Terry B's on here I don't THINK has that there in the pics I remember seeing.
      just making sure!
      thanks again!
      • Jack C.
        • 1090
        Look close to where I said it shoud be. You can see the bracket peeking out below the A.I.R tree.
        Jack Corso
        • Brandon T.
          • October 23, 2008
          • 872
          thanks, I see..it just supports the wires kinda like the plastic ones do on the valve covers.
          Yeah it's just been hard to see in pics probably.
          let me get this straight because this bracket and grounding on the valve covers is all I have left.
          cylinder ground lugs 2 & 4 go together under the 1st valve cover bolt towards the front of the car..and cylinder wire 6 & 8 go under the 3rd bolt back on the valve cover from the front correct?
          and cylidner ground lugs for cylinder 1 & 3 go together under the 1st valve cover bolt from the front..and cylinder lugs 5 & 7 go under the 3rd valve cover bolt from the front correct?
          and the bracket goes on the passenger side under the 2nd valve cover bolt..is their supposed to be a bracket like this on the drivers side too?
          • Dick W.
            • 10483
            The description in the Paragon catalog gives you perfect instructions as where it goes and how to install it.
            Dick Whittington
            • Brandon T.
              • October 23, 2008
              • 872
              I want to say thanks, this forum is so helpful!
              • Jack C.
                • 1090
                Looks very nice Brandon.
                Jack Corso
                • Terry B.
                  • August 31, 1999
                  • 607
                  Brandon,
                  Thanks for bringing this up about the spark plug wire bracket. My L-36 does not have it but according to the '68 AIM page 342 there is a notation of an existing wire support at that location. I'm not sure why just the right side and not the left too. Maybe someone knows and will respond. I will be ordering one soon.
                  Your car is looking real good. Keep up the great work!
                  Terry Buchanan
                  Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                  Corvettes Owned:
                  1977 Coupe
                  1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                  2003 Electron Blue Coupe
                  2019 Torch Red Grand Sport Coupe
