64 convertable is this carb correct - NCRS Discussion Boards
  • Vincent B.
    Infrequent User
    • February 8, 2010
    • 17
    I have a 64 with a 327 300hp engine. It has a carter AFB with a plate riveted to the top rim that says " Competion Series 625 CFM " How can I find out if this carb is correct or not?
    Re: 64 convertable is this carb correct
    Just flip your copy of the '63-64 Judging Guide to Mechanical, Carb and read the description of factory original AFB's...
    • Mike E.
      • February 28, 1975
      • 5138
      I notice that you're a new member--welcome!!! The carb you have is somewhat the right style, but incorrect. If I recall, you need a 3720 or a 3721--that would be stamped on the right front flange where carb meets the intake manifold.
      • William C.
        • May 31, 1975
        • 6037
        3720 for PG or 3721 for manual trans 300 hp car.
        Bill Clupper #618
        • Donald L.
          • November 1, 1981
          • 140
          The carb. you have is the type you buy from jegs or summet for any hot rod. not oriiginal
          • Vincent B.
            Infrequent User
            • February 8, 2010
            • 17
            I now have the Technical and Judging Guide. This is great. Thanks!!!
            • Vincent B.
              Infrequent User
              • February 8, 2010
              • 17
              Thank's for your help. The correct carb is on it's way.
              • Vincent B.
                Infrequent User
                • February 8, 2010
                • 17
                Thank's!!!
                • Vincent B.
                  Infrequent User
                  • February 8, 2010
                  • 17
                  Thank's!!!
