I am rebuilding a 1974-era distributor. Would a light coating of lithium grease take care of the main shaft?
C3 -Distributor Shaft Lube
Re: C3 -Distributor Shaft Lube
What part of the mainshaft? The bottom end bushing is lubricated constantly by engine oil, but the upper bushing never sees oil. If you mean the "grease well" below the plastic seal disc under the breaker plate, that well needs to be filled with chassis grease or packed with cotton gauze and saturated with engine oil; that's the only lubrication it'll ever see.- Top
FWIW, here's a Delco product (on the left) which has multiple uses [read the list], and the last is distributor shafts (probably the upper portion including tach drive worm gears). The tube on the right is a lifetime supply for the points cam.
- Top
Paul this is a excellent aritcle by John Fiedler who owns T. I. Speciality and rebuilds distributors and owns the web site this came from on how to rebuild a Corvette distributor. I used the 20 W oil as recommended in the article for the oil cavity at the top of the distributor.
Transistor Ignition and points style Corvette distributors from 1962 to 1972. Fuel Injection distributors are not specifically addressed; however, many items will apply to these distributors as well. My definition of restoration is to bring a distributor back to its original appearance and function by reconditioning the original parts, replacing parts only when absolutely necessary, and using the correct parts for replacement.Last edited by Jim T.; February 26, 2010, 07:07 PM.- Top
He gave me a few ounces in a small cosmetics jar, so I don't have the original label handy to read, but the grease is a dark gray color , not red, and IIRC the label said it is "siliconized". It looks like gray wheel bearing grease, but if you rub small amounts of each between thumb and forefinger the wheel bearing grease quickly becomes gummy, but the 1969954 remains very slippery.
I used it on the bushings when I rebuilt the CV starter motor and also in the grease well of the HEI distributor.
It's what I recommend for these applications if you can get your hands on some!
DukeLast edited by Duke W.; February 26, 2010, 08:31 PM.- Top
