Crosshaft removal - NCRS Discussion Boards
Crosshaft removal
  • Keith R.
    • August 31, 2001
    • 660
    Crosshaft removal
    How do you remove the lower inner crosshafts from the lower A-frame with the A-frame off the car? I got the upper A-arms off the upper inner shaft OK but the lower shafts are too long to slip out of the A-arm ears. Do you have to cut a seal? What am I missing?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
    Re: Crosshaft removal
    Keith -
    With the bushings and seals removed from both ends of the shaft, it should come free of the arm with no drama.
    • Keith R.
      • August 31, 2001
      • 660
      Thanks John. I had figured it out. Once I poked one of the old seals back through the hole in the A-arm ear I was able to remove it.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
