63 LH Splash Shield - NCRS Discussion Boards
63 LH Splash Shield
  • Harry S.
    • July 31, 2002
    • 5295
    63 LH Splash Shield
    The pictured LH splash shield has an indentation along the edge. This picture is from one of the parts suppliers.
    I just removed cleaned up and replaced the splash shield on my 63 and the indentation is not there it is straight.
    Thoughts?
  • Bill C.
    • May 31, 1989
    • 424
    Re: 63 LH Splash Shield
    Harry,
    The indentation you refer to was put into the shield later for the intro of a/c and the battery box moving to the left side, the indentation is for battery box clearance, I imagine they just made the one part with the indent for all applications. On later cars destined for A/C the RH shield ( which also has an indentation for battery box clearance on all NON A/C cars) actually had a small piece spot welded across the indent to fill it. If memory serves, this is found mostly on 64-6 cars then disappeared, again, probably found to be unnecessary. If one does a search, that topic has been discussed here.
    Bill
    • Harry S.
      • July 31, 2002
      • 5295
      Bill, thanks.
      Cheers
